se4riously..to e..SPC very low..could feel the lag in power..
but its cheap
- Yamaha FZ150I
-Yamaha FZ150I
  • Replies 638
Thankz bro for the Info....mybe ill try it myself once. If its lyt u said....got nuthing to say lorr, juz testing tis oil wether worth or not.
Cheerx
http://1.bp.blogspot.com/-YVDXr9jL_tY/TWF8NSTK0gI/AAAAAAAAAcs/qYJoFu19XWY/s320/DSC00549.JPG
Cheerx
I've tried SPC engine oil $8.50 several times on my 110cc kub. No probs cos i change it every 1200km. Now i using Total from Carrefour $5.90
Class 2bHonda TA150, Yamaha RXZ135, SYM Magic110, Kawasaki KSR110, SYM GTS200, Paijifa F150, Yamaha Cygnus Z125
Class 2aHonda CB400 Project Big 1, Version S, Honda Shadow 400
Class 2Yamaha Vmax1200, Honda CBR1100XX, Honda Deauville650, Honda CB1300, Yamaha FZ6S, Honda Varadero1000, Suzuki Hayabusa GSX1300R
wah seh.. more and more budget oil coming out.. haha...
thats exactly what i would do also.. use cheap oil.. change more often... or use expensive oil... change less often... cos it all works out to be the same in the long run....
'Il rettilineo è una tortura'
if got lobang for cheap EO then can DIY lah.. else why bother?
its never the same.. they are cracked diffrentlly..
they are diff quality...
why dont just stick to fully syn.. its better.. change twice a week...
cheers
skazuz
Honda CRM 125-2004-2006
Yamaha X-1(Red)-2004-2009
Yamaha Y125Z-2006-2008
u change twice a week??
- Yamaha FZ150I
-Yamaha FZ150I
Yar lorr....U change TWICE a Week huhh Skazuz. For REAL??!! sURE U very loaded wann change EO.....Fuoyyooouhh :bouncefire:
I've checked out even better deals across the causeway. Petronas Sprint 4T SAE40 only RM9.70, equivalent to SGD less than $4.50. Shall try it out after i finish my abundant stocks of Total oil..lolzz
wat is the viscosity??
- Yamaha FZ150I
-Yamaha FZ150I
SAE 40. Its a single grade mineral based oil
SIngle grade 40wt very very hard to crank when cold. Tried it out on a 600cc bike, even that was struggling and took forever to warm up.
Want cheap go buy those 5 gallon pail EO lah. Do not assume that good quality oil is only for extending oil change interval. The additives play a crucial role in protection.
I would agree to what ANR Impex says.
wow.. thats constructive...
Guys, didnt knw if dis is de ryte thread but ... I changed my own engine oil last nyte. U knw de bottom nut use to drain de used engine oil? Do u haf washer for dat nut?
Cos i tink, wen i remove de nut, theres dis cirlce ting lyk washer but it cracked into half. And after draining, i cant tighten the nut.
I need help here if u guys don mind. I cant ride to work. Is it because the previous shop overtightened my nut? Thx guys .... Ride safe ...
The spirit carries on ... Cheers! :thumb:
yeah... there is a black washer or whatveer you call it..
i think its better you bring the cracked piece and approach your bike shop for a replacement...
Its a special washer called a 'crush washer'. Don't just anyhow lup a steel washer in, it needs to be made of copper or other soft material. The idea is that this washer deforms and seals the oil. If you use steel washer, u deform the soft aluminum sump instead.
Thx a lot ... Will go tomorrow. Werk ends late todae ... Thx again bro
