guess no use one no matter wat u did...the problem is unsolvable.just live with it and don't spend any more money on things that claimed that can improve FC..:sian:
wat did u try on liquid engineering bro??
http://i847.photobucket.com/albums/ab31/mufarridun/395467_10151281899004118_1083329383_n_zps4299baea.jpg
You Will Bring Me Everywhere I Wanna Go :lovestruck:
Just installed this fuel saving catalyst called blackstone nanoball, heard tat it can improve fc by 10%... Hope it will really improve the fc from my next top up... Current fc for my spec2 is 20km/l...
is a money back guarantee stuff??
Spec III on yoshi endcan, 6-pt grounding, 1/4 bottle X1R.
riding style: amk to sch(TP) back and forth(mon-fri) fri nite go jb pump petronas
price: rm29-30 rate:1.8/L
route: amk towards ubi(70km/h) to old airport rd,open vtec(70-110km/h)..constant changing gears 4-5rpm(295-310 before reserve) total mileage: 380km
if holiday, rode to work @ joo chiat rd back and forth , went meetings or outings, expressways(320-340 before reserve) 410km
Honda Wave S125 (Mortal Kombat) FX 6045J [06-07]
Spark 135 (Transformers Cybertron) FBB 7182C [07-11]
Super 4 Spec III (Monster Energy III Red) FBB 2783B [08-11]
Honda Wave S125 FV 3157A [09-12]
FZ1S FBD 3365H [11-14]
Spark 135 (Yamaha Camel) FBB 4---M [10-current]
Honda CBR900RRR (Honda Repsol) FX 4---K [10-current]
Suzuki Bandit GSF1250K9 (20th Anniversary) FBE 8---R [14-current]
should be x1r too..
Spec1 using V-Power Johor, top up 17+lt RM35.00. I ever ran out of petrol along clementi road near Ngee Ann Poly. Mileage at meter shows 418km. This shows that my fc is ard 24.6km/lt.
walauweh ur mileage so good la.. mine sux big time..
Hmm... Dont think so...
hey pngming, care to share does ur fuel saving catalyst helps in fuel saving ??
http://farm2.static.flickr.com/1150/1426483839_2b47be539c_o.jpg
oct05 - oct06 runner 200
oct06 - july07 vtec1
july07 - ?? runner200
may09 - ?? vtec2
my max is 390km include resv.. i using yoshi full system.. xpress way most i ride around 90-100km change gear at 4.5-5.5rpm
JAN '08 - JUL '08 ~ VFR 400 (FH *1*3D)
JUL '08 - NOV '10 ~ CB 400 (FBC 3*3D)
NOV '10 - JUL '12 ~ CBR 600 (FBC *6*3K)
JUL '12 - AUG '12 ~ X-1 (FZ *2*3A)
AUG'12 - Sept'15 ~ SPARK T135 (FBE 4*2*B)
SEPT'15 - JUNE' 18 ~ Tmax 530 (FBG 8877Z)
JUN'18 ~ AUG'22 ~ XMAX 300 ( FBG 8877Z)
hi guys how come u all got yoshi exhaust milleage so good? im using yoshi and my fuel consumption is 250km pump petrol liao. just normal riding seldom open vtec, if open vtec 100plus pump petrol liao.. how come like dat? normal tuning done already..
250 km only?
So little? o_O
418??
Tats quite far....
So our reserve tank can go till?
yours is fs? at what rpm you change gear? what other things have you done to your bike?
hi nope. mine is only end can only not FS. im e 3rd owner btw. e end can is quite old and i got it quite cheap. just took it and test it and im surprised by e lousy fuel consumption. my bike is stock no modification. only got box, flower disc plates. rpm is usually about 5-6 change liao. if i change to GPR 1st hand (im intending) do u guys think itll help? appreciate all replies. tks..
i dun think age of the pipe matters.. some pple say 5-6k rpm change is too high but i change around this range as well.. fc is about 20-22km/l..
ok tks.. but hows yr FC after installing yoshi? i really regretted getting yoshi, my FC damn disgusting.. those who have good FC after installing yoshi pls come in and share how u all did it.. tks
the fc i reported is after i installed yoshi, before that using micron.. both pipes fc also in this range.. look for ahpek to improve your fc.. but if you conclude that its your yoshi that's giving you fc that bad then sell it away and use stock..
my trottle is quite tight izzit normal ??
a mech said its not normal and it will cos more fc ... must change trottle cable
another of my fren said its gd .... although more fc but better respond
so should i change my trottle cable ???
ta200 2003-2007
cb400 spec1 2007-now
im using stock now. FC is v good. 350 and above pump oil liao. only e yoshi issue is bad experience. now i wanna try GPR so wanna ask if its recommended. if its lousy then ill post it to sell off at good deal.
my fc with gpr , 19km/l
ta200 2003-2007
so at e moment are u happy using aftermarket exhaust? im stil wondering should i change..?
i'm ok actually ... been using it for 2yrs ......
like e carbon look (^^)v
ta200 2003-2007
