Found a website where you can get oils, in case anyone is interested:
http://www.lubeszone.com/index1.html
when using oil for over 10,000km, engage gear still being smooth as ever. Does it mean the oil is becoming more thinner as it prove not gd for our engine?
Been running on Amsoil since last year, no regrets...Great eo to be on..
No problem. And i hope you see that I'm not trying to win an argument, just trying to help you better understand the needs of your bike to maximise your biking experience. Once you have this experience, it can be applied to all subsequent bikes. So far there have been many happy endusers in SBF itself after a better understanding. The bulk of local bike servicing community is still hung up on thick is better and have differing and sometimes inaccurate theories on choosing a viscosity.
Viscosity affects gear shift because motorcycles are wet clutch with the clutch place soaked in EO. Different operating viscosity affects the clutch plate drag. Using a very thick oil is in effect similar to not clutching in enough, friction is still tranferred through the viscous oil film. Putting the bike on main stand, start engine and engage 1st gear while remaining clutched in, you will see the rear wheel spin. The power is transferred purely from oil friction.
The motocycle sequential shifting system is very particular about having just the right amount of 'tensioning' to get the gears to engage smoothly. Too little and you need to play your clutch to find neutral, too much and you find the gear shifting very stiff.
Hi,which is the best maxima EO you can recommend for the new Honda CB400 Revo,i really like to try it out? Thanks
Rides from 1991 till current:
Kawasaki KDX 200
Yamaha Rival 125(Stop production)
Suzuki TS 200
Yamaha TZR 125
Piaggio Corsa 200
Vespa Exclusive 2
Honda Wave 125
Honda CB400 Revo
Yamaha FJR 1300A
with all due respect, ANR Impex had r.i.p. few mths back due to accident if i'm not mistaken.. for s4, usual takes would be:
maxima extra 10w40 - gd for quick pick ups
maxima extra 15w50 - if wan smooth gear change & long distant trips
maxima ultra 5w50 - best of both worlds.. haha but costs a bit more :thumb:
http://img.photobucket.com/albums/v639/asyie76/1098771948_1777077031.gif http://img.photobucket.com/albums/v639/asyie76/1111207576_1257877726.gif
if Life ain't any Better..
seek Death & u'll feel Lighter..
which types to recommend?:)
Hi.
Between Maxima 10W40 and Mutol 7100 10W40, which is the prefered by most riders?
2017
2018
2019
Just thinking if motorbike can use those big bottle 5 liters engine oil for cars?
Cos they are cheaper and some even got the same model use for bike
has anyone tried Royal purple engine oil from the USA?
Most people go through life following the crowd.
Others think for themselves.
They go their own way.
Not recommended. You can use...coz some using for their S4 and no complain.
Y not recommended??? This is because car uses dry clutch system while bike uses wet clutch system. So there bound to be differences in the EO.
* Suzuki GSR750
hi guys, need ur help on my 5k milage x1r, everytime i change engine oil, i always change to fully synthetic one's and this the problem, whenever i clutch in and lower a gear it has a very loud "tiak" sound, is it because the oil not thick enough? By the way, i used putoline and maxima before for 1st few engine oil change and now using motul 300v changed twice.
Heard Maxima and Motul are the best, wats the best after that?
S4 Spec3 Aug 2007 - Mar 2010
GSR400 July 2010 - Oct 2011
anyone knows what is the difference btw 10w40 and 15w50....what is the 10 and 15??
what is the 40 and 50?
which brand is good for cbr1000 06
Accident have no tell tales sign. It take a second to kill but a lifetime to prevent.
Bro...try maxima 15/50
2008-Spark 135 & Kawasaki KLE500
Hi guys,where to get the Amsoil eo?
Was used on my bike b4,but i changed to motul 300v..
The smoothness of the engine seemed to last me only 1000km..
The difference between men and boys is the lessons they learn
any recommendations for semi syn oils? using old bandit, and fully syn not vicous enough to stick to cylinder walls or something like that im told
"I don't trust any bike I can't see through" - jay leno
btw now giant is having a sale on engine oil the 4 lit one
4 lit for 68.90 if i not wrong, it 5w40 if i not wrong it is oso fully syn
the brand is mobile 1
bike history
1987 - 1988 - Baby steps
1989 - 2005 - Bus,Mrt,Taxi
Nov05 - Jan07 -YBR125
Jan07 - Feb11- CB400 Spec 1
Mar11 - ??? Fazer 1000
Nov05 - Got Got Class 2B
Dec 06 - Got Class 2A
Nov07 - Got Class 3
Mar08 - Got Class 2
10W or 15W is the viscosity grade of the oil at 0*C(winter)..-40 or -50 is the viscosity grade at working temperature. Higher value means thicker oil. We shd look at the number at the rear instead of front cos Singapore no winter.. :cheeky:
We shd be looking at -40 or -50 weight oil..but it depends on what oil/brand/manufacturer you use. Most fully synthetic oil are not really synthetic base..very few brands here are actually true synthetic oil.
From where I read, petroleum base synthetic oil will breakdown faster and degrade 1 viscosity grade lower when compared to ester/PAO base synthetic oil during high speed and high temp operations.
To be safe..choose true/pure synthetic oil where its made of ester/PAO if you wanna use synthetic oil. If using a petroleum base synthetic oil, choose -50 cos if it degrades, will degrade to -40..
Juz my 0.0002 cents...
I'm going to change to Amsoil too..HKL has them stocked..
From where I read, petroleum base synthetic oil will breakdown faster and degrade 1 viscosity grade lower when compared to ester base synthetic oil during high speed and high temp operations.
To be safe..choose true/pure synthetic oil where its made of ester if you wanna use synthetic oil. If using a petroleum base synthetic oil, choose -50 cos if it degrades, will degrade to -40..
How's amsoil performance? Price per bottle?
