I doubt tats NORMAL... do check it out bro.
Hi HaiR1
I went back to the bike shop, He told me its totally normal and insist that my carb diaphragm is spoiled.But its perfectly fine to me. Any idea what could be the problem?
Hi HaiR1
drop by my place @ J.west if u happen to be near.. i try to figure out... check my profile for my no
Hi byon, u usin which yoshi full system on wad spec ?
Sorry off topic is jetting require for e full system n where u did ?
Im quite keen to get a yoshi fire spec full system for my spec 3 but afraid it might affect e fc.
Tri-Oval. No need. Go for dynojet after ur full system installation.
Well, the fc is good for me.
My SpecII, all stock with leovince. Petrol consumption quite bad. Full tank 220km only. Is it normal? Or what the problem is?
Yamaha Supreme X1 - April 2011 till September 2011
Kawasaki KRR ZX150 - September 2011 till August 2012
CB400 VTEC II - August 2012 - Current
"I Don't Ride Fast, I Fly Low"
220km full tank is wtf bad
220/15L=14.7km per L only?
Yamaha x1
Honda super 4 spec 1
:cheers:
Yup... not sure why is it so bad too... any reasons that might caused it?
just started riding revo last week. my mileage was about 200 and i hit reserve. pump about 15l.
is 200km normal? i doubt so?
Class 3 : 6 Jan 2011
Class 2B: 22 June 2011
Class 2A: 26 July 2012
Class 2: 20 Sept 2013
R15 BumbleBee
CB400 Revo
Ducati 848 Evo
Honda Wave
Honda Tiger
Try to pump full tank and monitor...u should able to hit at the very least 300 before hitting reserve
:angel:RIDE TO BE A GHOST RIDER:angel:
maybe i should monitor a few more tanks see how it goes =)
anyone tried stp gas treatment?
Class 2bHonda TA150, Yamaha RXZ135, SYM Magic110, Kawasaki KSR110, SYM GTS200, Paijifa F150, Yamaha Cygnus Z125
Class 2aHonda CB400 Project Big 1, Version S, Honda Shadow 400
Class 2Yamaha Vmax1200, Honda CBR1100XX, Honda Deauville650, Honda CB1300, Yamaha FZ6S, Honda Varadero1000, Suzuki Hayabusa GSX1300R
Im using rear sprox 42 and used standard headers with bf endcan, engine stock. Went 160-180 on the NSH. Managed to get 210km before my reserve starts to blink. Now using 4-1 headers havent tested yet. Dude 38 is way to small. Your moving off will suffer. Rear 42 already suffering bro.
Thrash? Don't mind if i do.
fuel additives like stp, do they actually work?
thnx fr d info bro...but fr my riding style is 80% touring...so i dun think 38 is a prob...almost every week KL-Spore-KL...between 3000km to 6000km per mth...
My idea is to change sprocket size 520, not standard 525...cz 520 got one set RKM...i can get cheaper at Sentul,KL (so called motorbike shop heaven) as RKM is made in M'sia....my Yamaha FZ150i also change sprocket at Sentul...Heavy Duty RKM Chain&sprocket 428 set fr my FZ150i only RM55...
I gave up to O-ring chain to my FZ150i as it last very short (12,000km) altho i owez lube it every 300km :( it was DID...so i give up on DID now...better RKM dat i'm using now at my FZ150i..can last more thn 20,000km as i expect fr my FZ150i as i lube every 200km...
Hi Bros,
Heard Of BROQUET Fuel Charger? :lovestruck:
1. Want more Extra Mileage from your Fuel? :thumb:
2. Dyno Run shows an increase of HorsePower after installation of BROQUET !
(Proven By DYNO chart) :thumb:
Check out my CMO thread -- >
http://www.singaporebikes.com/forums/showthread.php/235030-lt-CMO-gt-BROQUET-Fuel-Charger-(UK)-NEW-(Torque-Top)-DUAL-MODE-SELECTOR-Voltage-Stablize
Edited by vtec88
Hi Guys,
I am riding a S4 Spec 1.
Just wanna check, is it true that the FC will be lower if I dont ride often? I recently got a 20.7km/L from my full tank. Haven been riding often though. Its like once every 1-2 days interval, and i notice the fuel gauge is lower when i came back from an overseas trip of 4 days. So wondering is it normal to have fuel leaking slowly?
I also heard that older S4 cannot pump good petrol like 98 or V-power? Cuz the petrol chemicals are too fine for the engine. 95 will achieve a better mileage?
I'm doing on 98 Caltex currently. Any recommendations if I have to change? Would 95 be recommended? Which company petrol can achieve the highest mileage? I only do SG pumping currently. Will try M'sia in the future.
Thanks for all advice.
Hi Guys,
if u dont ride often, your fc will be poorer.
i've tried that before.
Yamaha x1
:cheers:
Hi Guys,
IMO..
Sometimes, someting tat U have to try out yourself n not based on what your friend says...
I been using SG Esso8000, Caltex98, Shell VPower..even MLY Esso 'F1'.
The diff in performance n smoothness n ECT U will notice.. Try pump top SG petrol for 1 month & try switching to MLY petrol if U wanna experience it..
Noticeable diff but not tat great..
Milage wise, as stated above.. Depends..
my best was about 420km till bone dry
have a ver s, gets close to arnd 200km for arnd 10 litres..always using spc levo 98..is that the expected?
Bajaj Pulsar 180 - May 2006 - May 2007
Hyosung Comet GT125- June 2008 - January 2010
Honda Phantom TA 200- January 2010 - 2012
Honda CB 400 Ver S - 2012 - Jan 2016
Adiva AD2 200 - Jan 2016 - July 2016
hi guys, im on spec1. cruising on xpressway usually 100-110,bike all stock. will last me only about 230km, usually i have my gf behind me. is this normal? cos reading here, most get about 300km. so kinda worried?
should be on the average side. unless you expecting to get more out of the fuel.
230 until dry or until fuel gauge blinking? either way not so normal.
230 then start to blink. im consoling myself by saying that i always have a pillion behind. most times i pump jb esso f1. tyre pressure front and back is what ah?
250f 280r for me. Also pillion most of the time. I can hit 320 before blink. Alot of factors can lead to bad fc.
The max I pumped before is $21.00++ of Shell Fusion petrol
http://www.rxor.info/01.jpghttp://www.rxor.info/22.jpghttp://www.rxor.info/8.jpg
http://www.rxor.info/03.jpghttp://www.rxor.info/23.jpghttp://www.ryzu.info/9.jpg
