hi ppl (:
can anyone pls share with me if ur s4 rear brake is efficient?
over here, my problem is when i try to brake using the rear brake, it does not seems very efficient? my fren who is riding cbr400 oso had this similar problem. and my bikeshop fix a new pair of brake pad (rear one) for me. it does not seems to improve. he told me new brake pad need to season, but pass a few days ardy and i keep riding, seems not to haf any improvement. what is the problem?
hope u guys can help me with this (:
cheers.
Edited by sino74
respect all; peaceful rider Ride safely, be happy. :p
  • Replies 362
hi ppl (:
cheers.
Maybe you should try bleeding
Anyway s4 brakes dun really "eat" well
If you want better braking power then you can change to aftermarket brake hose :)
if bleed of air still cannot, try spraying some oil to the brake pump.
Yamaha FZ1S: Nov 09 - May 13
hi ppl (:
cheers.
the rear brakes are for slowing down in combination with the front. No issues on that.
http://img.photobucket.com/albums/v189/Loontoot/Funny%20Pics/adminuser4mw.gif
<CMO> Quality IT Services for homes & businesses.
<CMO> 3M Products from U.S.A
is ur previous bike's brake syst single rotor for the front? if so, u hav gotten used to the braking pressure u apply for the previous bike, n maybe tt's y now u feel tt the rear brake of super4 has less braking power, cos super4 uses dual front rotor syst.
hi ppl (:
cheers.
http://us.a2.yahoofs.com/users/44752b98z3c3f89f5/ecd2scd/__sr_/2511scd.jpg?phIyRjGBn4QWup7H
i also find S4 rear brake is very weak. got to apply more pressure than a light tap just to prevent it from rolling back on a slope. Last time when riding phantom its rear brake is very effective.
During stopping i normally apply 70% or more of front brake.
May 2005 - July 2007: Honda Phantom TA200 (FU 3*** S)
July 2007 - Dec 2016: Honda CB400 Spec III (FBB 7***X)
Dec 2016 - Aug 2017: Yamaha FZ1N (FBD 4***E)
Aug 2017 - Present: Kawasaki Z1000SX (FBF 6***B)
Boono :cool:
maybe need to change brake disc liao??
2006 - 2009 Super 4 spec II (FV **43 first ride)
2009 - 2010(jan) FZ1 08 (FBD3***)
2010 - 2013 Hayabusa 06 (FBA****)
2013 - ???? Tmax 2013 (FBH****)
http://i97.photobucket.com/albums/l212/shadowles85/sign1.jpg
disc brake? as in s4 not using disc brake on the rear??
yup buttbutt8, i think all of us has the similar problem. front eat, rear dun eat.
unclevtec, maybe so. cos i riding phantom previously. but comparing rite, phantom rear brake seems more efficient to me leh?
ztaik, maybe u haf to check if ur brake pad is finishing? or it may be normal if ur brake pad is "black coated". my 2 cents (:
wonder why my rear brake disc was like kinda black, like burnt marks.. any wrong with the pads?
Your disk are already burnt. Need replacement, cause of problem pads rubbing against the disk while on the move thus causing over heating and causing material failure. Maybe your right leg's stepping on the brake pedal or your rear caliper's jam.
I don't have this problem of rear brake's not biting. Check your brake pads maybe it had been polished shiny. You need to go easy on your braking for the first 500kms as told by most brake pads manufacturer. If not your pads will actually be glazed and will not be as effective.
brake pad n rotors r alway in contact with each other. only no pressure is applied if brake pedal is not compressed.
anyway, brake pads shd b made of softer material compared to those of the discs. cos brake pad is a sacrificial item cos its cheaper than the discs. simple to say, we change brake pad more often than brake disc. salesman might say brand A pad is good, rossi is using. but thats for track use. road use? can use but not that suitable. anything wears out fast, need to replace, we as end users pay n not the salesman.
Yes of course they are constantly in contact with each other. What happens when apply additional pressure constantly? The brake pads will heats up and thus glazing the pads. If continue to use pressure and contact for the next several hundred kilometers then the result will be burnt brake rotors. Cos I use to face this problem my right leg will unknowingly apply pressure on the brake pedal thus the rotors got heated and turns blackish. I re-adjusted my riding position and now got no problem.
The rear brake is always less "efficience" for few reasons :
1) During braking, the bike weight will shift to front. The rear brake has less effect.
Under hard braking, the effect is more obvious. Until a point that, the rear wheel will lift up and lost contact from tarmac.
2) Rear brake 'too' efficient will cause wheel lock.
Thats why most of the bike (even for cars) has bigger disc brake at front but small (single disc or drum brake) at the rear.
** Be smart, ride safely, stay legal **
Please read the << Street Smart >> thread.
i had this prob too... every bike shop i go will ask me to change my brake disc due to roughness on the surface and brake pad cannot eat properly at the brake disc.
http://img42.imageshack.us/img42/8771/offroadtm7.jpg
My Motard make wonders:thumb:
yes yes, went to my motordiam today, i ask em why they change new brakepad for me still dun eat. last tym tell me need some time to season. but after 300-500km still the same.
this tym they help me check thoroughly. is bcos the rear disc plate not flat anymore (rough surface) tts why cannot eat.
hi ppl (:
cheers.
how about concentrating more on front brakes ? rear brakes r never more efficient than the front
school always teaches 70% front 30% back..
rear brake not biting a lot doesnt matter.. unless you say not biting at all..
you dun wanna do counter steering when you jam e-brakes with a very sensitive rear brakes..
yah, maybe i have not get use to a bigger bike ba. now feel better wit the condition ardy. thx guys for the advise !!
cheers !! (:
thinking about it, why does rear tire tend to skid ah? they are bigger then the front one what?
is it because of the weight throw forward thing when we're braking so the rear tire 'lighter'?
Sept 06 - Feb 08 = TZM
Feb 08 - April09= CB 400 Version S
May 09 - Oct 10 = Harley XR1200
Oct 10 - Oct 12= KTM SMT 990
Oct 12 - Oct 13 = Tmax 500
Mar 13 - Jul 13= SYM maxsym 400
Jul 13 - Sep 15 = Getz 1.4
Oct 15 - Now = Burgman 650
Never ride faster then ur guardian angel could fly
rear disk brake "pad" cost as low as 25 per pair or even 65 above per pair. pay more get better one u see?
rear disc brake "plate", i was quoted 150 for original honda wan. oso got japan and china flower plate. 90 can get.
