IF NEVER change oil filter 3L is enough but if got change oil filter then must need 3.2 L liao
http://i109.photobucket.com/albums/n62/anric79/5073085f-2c95-4b2c-937d-c905dcca4fdb.jpg
  • Replies 833
Yes. 3.2L is whenu change oil filter :smile:
http://i15.photobucket.com/albums/a380/VoxArcana/Forum%20Signatures/ManUtdChampions.png
2002 - 2004 HonDa SP
2004 - 2006 HoNdA S4 VtEc 1
2006 - 2007 YaMahA MaJesTy 250 MK2
2007 Current HoNDa SliVerWinG 400
Originally posted by RobbenArjen@Nov 8 2006, 02:28 PM
hey guys i jus change my maxima extra engine oil.
ok im very happy wif the product but wats bothering me is
when i change the oil .. the mech only put 3litres of oil.
from wat i noe my spec1 needs 3.2litres rit..but he says if nv change oil filter
3 litres is enough
is it true ?
U can always check on your right hand side the clutch housing below. There is a transparent round thing to check your engine oil whether is it sufficent a not. Try to make your bike centre, more accurate.
世上最é¥è¿œçš„è·ç¦»æ˜¯æˆ‘站在佪的é¢å‰ï¼Œ 佪å´ä¸çŸ¥é“我爱佪。
2000 to 2002 : HONDA NSR 125R FM 7541
2002 to 2006 : CBR 400 L MODEL FN 3561
2006 to 2007 : S4 SPEC II FW 2118
2007 to 2009: 92 Civic Esi SBU 7959
2009 to <Present> : Lancer Ex 1.5 (S)
Originally posted by Vincent80@Nov 10 2006, 12:17 AM
dun worry brother.
I always change my oil filter and my EO.
The max EO i pour in is only 3L.
I ask my boon siew mech and they all also do to my bike when i send there for servicing.
So bottomline 3L is enough.
Even if u change the oil filter.
huh ?
is it?
erm i always tot with filter change is 3.2
hmm..
:confused:
No point tail-gating me.
Im already on the left lane.
for spec3 there is a engine oil indicator, the mechanic told me not to worry sufficient or insufficient oil cos if insufficient EO the indicator light will light up..
there are 2 ways to check,
1. the side bottom EO window, when bike is upright, make sure the EO level is between the max and min marking.
2. use the dip stick, also when bike is upright, take out the dip stick and wip it clean of EO, dip the stick into the engine and screw to tighten. take out dip stick again to see if EO mark is between max and min...
it will be too late when your engine oil light is up... imagine you are not NSHW and the nearest petrol station is 150km away...
http://img407.imageshack.us/img407/7720/dsc00157a.jpg
All Must Work Hard!
dun worry brother.
Tats something new to hear for me..
dun worry brother.
Wow~ Dats realli somethin new i come across... :smile:
Den how abt the 200ml of EO when u take out ur oil filter? No need to refill back ar?
http://i6.photobucket.com/albums/y214/kea182/PIC_0120-1.jpg http://i6.photobucket.com/albums/y214/kea182/P1040229.jpghttp://i6.photobucket.com/albums/y214/kea182/PIC_0128.jpghttp://i6.photobucket.com/albums/y214/kea182/Signature01.jpg
Originally posted by Ah_Pek@Nov 12 2006, 12:43 PM
no change OF - 3litres
change Of - 3.2 litres..
is inside manual..
follow manual no wrong...=)
haha yeah
after a few more rounds of oil filter change then it will be clear to if the 200ml is needed or not... :cheeky:
5 oil filter change = 1litre EO less... i am not sure if the bike will even run or not...
All Must Work Hard!
lol... joker....
dun think it works that way.
its always gonna be 200ml short, no matter how many times the engine oil is changed.
i had a spec 1 some years ago...rode it for 80k+ kms...every 5000 change oil
with or without oil filter,i always use 3 litres
if u take a closer look at the oil filter,it is in a inclined position where if u park the bike on side stand,oil will flow back into the oil sump from the filter,leaving a quite neglible amount in the filter
and fyi a bottle of 1 litre of engine oil,if u measure the amount is usually around 1050ml
--- A twist of the wrist ---
the truth--------------> vtec family, 3l wiitout oil filter change, 3.2 wif oil filter change.
if ur not sure, put ur bike uprite and ask sum1 to see the glass window of the eo and u can see its in the middle. u wun go wrong. i diy my s4 every servicing.
ur user manual is crucial 4 ur bike knowledge.
All can...
as long got 40 or 50 can liao...
10w 40 or 5w 40 better right ?
Whether 10w or 5w does not matter cos singapore hot country.
Wat is important is it must be at least 40 and above.
yeah
the number in front of W is to indicated
the testing at winter temperatures.
i.e 5W is tested at -25 Deg
so actually does not really matter in SG
correct me if wrong bros
:cheeky:
whether 40 or 50 is all depends on how old is ur bike.. if ur bike is more that 5 yrs old then its best to aim for a 50.... for the W part its up to u.... but for me i use a thicker ones like 15w... cos my bike is bout 10 yrs old already....
