Originally posted by RxzDelux@Nov 8 2005, 07:21 PM
Which Maxima u using? Is it the Extra15W50 or Ultra5W50? :confused:
10w40 i think....
http://i16.photobucket.com/albums/b12/Ah_Hia00/Thai/MaeSod.jpg
My Bike Outside The Immigration Checkpoint of Mae Sod(Thai Mynmar Border), Mae Sod, Thailand
25th Dec 2005 to 9th Jan 2006
Singapore - Malaysia - Thailand
Total Distance Covered ~ 7000+ km
  • Replies 638
Originally posted by RxzDelux@Nov 8 2005, 07:28 PM
Ya It's true Wave is better on fully synthetics because it may offer more mileage and protection dat is if u can afford it. Fully synthetic r expensive!
Whereas semi or hydrocracked oil break down faster and offer less heat and protection to heat?
I don think so. I have been using my Wave on most range of engine oils be it expensive or cheap and now I am still running it wif Hydrocracked oil. Bo taiji. As long as u keep to the drain intervals and monitor the engine oil level. Should be no problem.
To each and own preference.
:cheers:
Then why keep to drain intervals if oil doesn't break down ??
All oils will break down after a certain heat range.
Fully syns just happen to have a higher tolerance level compare to hydrocracked oils.
Just a note.....
U are running in your wave with a range of oils be it exp or cheap ?
U should be running it with mineral oils and then use syn after the run in process....
oh well...like u said...to each his own....
Just a note.....
The answer is simple. It's because after long usage the oil will get dirty and Wave engine does not have oil filter. Futhermore after long usage it will lose it's viscosity to a lower viscosity. That is why need to have drain intervals.
So far I use semi-synthetic = bo taiji. I somemore always full throttle. How high-rev can a Wave gooo? The highest I have tried so far is only 3 and a half rpm only? Wave is not sports bike la fren.
This part maybe u partly correct. Fully synthetic may have longer mileage compared to the semi-syn but not all fully synthetic can giv extended mileage base from my past exp.
I got use lots to name a few popular brands one I have tried Motul(JB), Fuchs, Maxima, Castrol, Conoco, BlackGold, Idemitsu, Penzzoil(JB), Repsol, Total, Shell, Mobil, Elf and Redz. Some fully syn and some semi-syn and my engine still smooth like new.....
History n Present ride
Ok...u do it ur way with ur knowledge of oils.
I'll keep it to mine.
:cheer:
A classic example of listening to friend say and than do without even thinking.
If you only add a bit of 2T and its the first time you did such a insane act, don't worry cause not much harm is done to your engine. The 2T should have flown all the way down, by gravity, to the oil pan at the bottom of the bike engine when you park your bike overnight. It will stay there indefinately unless you drain all the engine oil out, flush with petrol and than replenish again.
125km/hr to 0km/hr in 1 sec will make mince meat. Ride slowly to show off your bike, Ride slowly to save your life.
Ex-Girlfriend:
Phantom TA200 (Blue) FV7889U
Piaggio Hexagon (Ducati Yellow) FM4183T
Piaggio X9-250cc (Blackies) FT4920S
Honda Wave-R (Bright Bright Yellow) FZ4494Z
Current GF (IN USA),
Ford Taurus 3.0L (Blue)
http://photos1.blogger.com/blogger/8164/562/1600/RX-78-wallpaper.jpg
Originally posted by ah_ham@Nov 7 2005, 11:15 AM
huh...? so serious ar.... so how to i ask 4 cleaning? clean wat i tot clean
engine is overhaul liao huh? any trustworthy shop to recommend?
thanx:cheer:
Try to change engine oil first. Just my suggestion though...........
Originally posted by ah_ham@Nov 6 2005, 02:03 PM
hey guys... this is wat my fren told mi de... wave to 2T in our petrol tank...
i dunnoe the ratio of how much 2T to petrol la...
Is it true? will the engine give way..? Or any side effects....?
I tried once.. it really gain power.. once ur petrol finish...
2T also finish liao... but i still scared scared leh....
Pls ease my scareness thanx! :confused:
:faint: :faint: :faint:
obsess with power.. 2T in 4-stroke. they call it 2T for a purpose.
MERGED THREAD
Topic : What's the Difference between Oils?
Description : Please help
What is the recommended engine oil type to be used for Wave?. Synthetic of Semi Syn? What brand would you guys suggest?. I travel about 120km a week incl weekends. Please let me know. Thanks.
Total Mil - 3000km
Cheers
Gurd
!! **** the Rest !!
if u don't mind forking out money, i would sugest using fully Synthetic oils by penzoil or other leading brands. or Esso gold. if budget, at least use semi-sythetic oils.
Living is the only thing worth dying for.
http://photos-d.ak.fbcdn.net/hphotos-ak-snc1/hs173.snc1/6493_120922975414_754135414_2532275_3624732_n.jpg
May 2005- December 2007 - Yamaha 125Z
December 2007 - Suzuki DR-Z 400-SM K7
mineral oil = never change at all
:sweat:
Honda Wave 110s - FT7476M
Honda CG 125 ----- FK7947T
Suzuki Bandit 400 - FM 8039Y
Yamaha Fazer 6 --- FW7537E
Honda Steed ------- FN 5565R
Yamaha YP 250 - FS2578R
Suzuki DL650 ---- FX9497T
can try esso gold
ah boy selling at $13 onli..
quite gd..
(Mar05) Honda SP 150 FR9470B
(Nov05) Kawasaki KRR 150 FU8637D
(Sep06) Suzuki GSX400 FK7652
(Nov06) Yamaha Sparks135 FBB511H
(Mar07) Honda RVF400 FN4991T
(07-10) Yamaha YZF R6 FBA7370G
(08-09) Suzuki DRZ 400 FBC4821G
MERGED THREAD
Topic : Wave engine oil
Description : mineral or synthetic
can wave use fully synthetic engine oil?
how many litre of engine oil needed for oil change?
:cheer:
yes....0.7L is the recommend volume as per the HondaWave manual book.
But 1L will do no harm.
Syn or min, is up to your pocket preference.
If you buy wave mainly is to save money, then the cheaper oil will be recommended.
If you got money to burn, then more expensive oil will be recommended.
There is no right or wrong.
Milliongs of rider in malaysia and vietnam all use cheap mineral oil and they are still riding it all day long.
Just look at those old kup riden by old ah-peh, last time where got synthetic oil. They 20years old bike is still working up till today. You think most ah-peh use synthetic oil or mineral oil?
MERGED THREAD
Topic : wats the use of a oil cooler?
Description : looks like a radiator one..
my fren gonna sell me one.. wanna know the function fo this oil cooler..
http://i3.photobucket.com/albums/y59/i_luff_21/Jingle/special.jpg
as the name of the item...
make use of moving air as ur bike travaling... to cool engine oil..
2000 -- Daelim 125 | 2001 -- VFR400 NC30
2001 -- GSXR400 | 2002 -- Super4 spec2
2002 -- Fireblade400 | 2003 -- VFR800 Vtec
2005 -- Suzuki RaiderR150 | 2006 -- Kia Rio 1.6 HB
2009 -- Super4 Revo | 2009 -- HD VRSCD
2010 -- HD Softail Heritage | 2010 BMW R1150RT
http://i33.photobucket.com/albums/d79/menphis3435/gals/miwaoshiro0287uh-1.jpg
Err... does an oil cooler comes with a pump? If not how the engine oil flow thru the radiator?
ur oil cooler for wat bike?
Honda CRM 125-2004-2006
Yamaha X-1(Red)-2004-2009
Yamaha Y125Z-2006-2008
