no la, just like to mod lor.
u mean remove it or ?
is it easy to remove ? do u have a picture of it?
It is easy to remove if you know how. No picture of it. Google it.
KRGT-1
  • Replies 224
You installed a hi-cam and didn't know that it would be harder to kick start. My guess is nothing's wrong, you might just be not used to it.
Me might need to hit the gym and work out those legs! :lol:
KRGT-1
Hi ,
i m looking for a Yamaha Spark T135. Preference : white, Stock(minimum modification).
please PM or text me @ 90221552.
27feb2010 - Passed 2B
Looking for yamaha spark t135 now.
Affordable + Speed = no 'class'
Affordable + 'class' = no speed
Speed + 'class' = NOT AFFORDABLE !
Anyone have spark accessories do inform me .
Is it common or there's a problem with my spark as I just bought it new first hand and as days goes by, my spark became harder to kick start. like when I first brought it out from shop and around the second day it requires just one kick and can start. now like 2-4 kick then can start. sometimes the engine just dies off and i have to start again...
hi there, i have a prob with my bike, when i ride at low speed, i heard a sound at my rear wheel? is it my rear bearing which is making the sound? coz my chain seems to be ok..
Hi guys, i've just bought a vixion kit. Need help from u guys what things needed to change/modify to make better performance. Now running on rextor adjustable cdi & andrion ignition coil. The rest are stocks. Please pm. Thanks~
my bike is jerking when i brake using front brake. the jerk is feels like the handle like looseloose kind. but i know handle nv loose. whats wrong ah?
Try change your spark plug.
What kind of sound? If it's coming from the rear wheel, check your rear wheel bearing. Might be loose. But don't think it will make sounds.
Your handlebar conbearing is loose. Get it tighten, or better yet, get it replaced. :)
**Wherever there's a need, there's always the highway!**
i ask the mech he do he say he say dunno... he say just fix but i think when i change the conrod when i kickstart it is really hard...... he say the compression of kickstart got power a bit.. i was like?????????? wad is he talking??? any guy experince a lost of fuel consumption when u overhaul your engine... or change yr conrod??
frm wht ii learn frm frens tht rides ,, aft eu overhaul ,, eu need to tune again ur carb..sorta carb service oni .. to adjust back to original ..cos gasket , piston , conrod , block ,, all getting season together .. so eu just need service/tune ur carb ..
my bike ges wobbly when i hit the speed of 110-120km/hr..
anyone can help?
ur handle tighten ? might be loose.
hi there.. I got this problem that i really not sure with. I riding a Spark 135 FBA. When i ride a few distance, then my engine will suddenly stop. Then when i want to start back. it take a very long time. Around half an hour. Pls help me. I want my bike to be good form ASAP . thx
recently my spark 135 keep stalling during cold-start and moving off. change spark plug and air-filter solve the problem. just for information for those whose bike getting sluggish.
the mechanic recommend changing air-filter every 5000km and spark-plug every 3-4months. i changed both at 6months.
Hi there, i new in riding spark :D
My spark FC like dam pathetic, comparing my spark with my friend one, mine 2 tank = his one tank.
any one got any idea what problems i might be facing regarding the FC problem ? both spark stock T.T
ur full tank can get how many clicks(mileage) bro?
thanks for replying bro, bought this bike less than 2 weeks from shop, didnt know what they modded too.
my 1 tank i think close to 100 clicks. i didnt over rev while riding lei, normal cruising only.
any ideas what problems i might be facing ?
  • 3 months later...
hi guys,
i need your opinion -> when my bike is going uphill and in increase throttle, the rpm suddenly goes damn high (loud sound)but bike no power. Then the rpm goes back to normal and then bike slowly increase speed.
Anyone knows why is this so?
hi guys, I need to some clarification on my bike. I seldom use it (as I'm currently in NS) other than book in and book out. etc. Maybe because of the rainy season I didn't warm-up my bike properly or what. I noticed, after some time, that some weird things happen to my bike. At some point there's this clicking sound like screw knocking on something near my carb. Then it stopped and my bike is back to normal. Now, I feel that when I'm on gear 3, I seems to notice like my bike is running out of power I have to increase throttle, like as if the rpm drops at the start of gear 3. Only in gear 3. Once I changed to gear 4, just a slight twitch on the throttle I'm off and my rpm stabilizes...
get your carb serviced... not many shops around know how to service a carb with an accelerator pump!!!
sorri ro hijac dis space,need to do some testing!
%5Bimg%5Dhttp%3A//i919.photobucket.com/albums/ad37/fesa7044/Ducati_desmodromic_cam_animation1.gif[/img]
