Bro, I think 28km/ltr is good, doubt it is extremely lean. My Old Suz Bandit 400 managed 24km/ltr. My Suz Dr200 can hit 30km/ltr. Review states Wave 125 can hit 40km/ltr.. BTW what's your bike make model?
91-92: 84 Yam LC125
97-01: 95 Suz Bandit400
01-04: 96 Suz DR650SE
04-11: 99 Suz SV650S
05-05: 94 Suz DR200SE
11-12: 02 BMW F650GS
12-16 01 BMW R1150GS
When- Burgman Tmax ??
  • Replies 598
i dun believe adding 2t for a 4-strokes engine is any good but depend on bike setup circumstances.
i did tried a theory calculation n real life run on stoichiometric fc (14.7:1 A/F mix by wt) for my roadwin 4-strokes 125cc engine, i'm off by a decimal point.
my butt dyno n spark plug electrode color (brown) seem spot 'ON' the mark for my 125cc engine.
most stock bikes runs lean tat why the engine is very hot.
many years of riding, on avg for carb type bikes 400cc should avg around 20~22km/l n 1000cc should avg around 12~14 km/l @ avg 100~120 kph.
nowadays EFI r more accurate in metering fuel but still on the lean side. it's better install Power commander V with auto-tune for optima performance.
when a bike is set to runs lean, u dun enjoy riding it coz it is under power with a very hot engine.
Edited by stsoh
i'll contribute 10 bucks as well, and post additional details on my 2t, no 2t fuel runs.
update.
2nd tank of 2t infused petrol. 36km/L.
so this shows that adding 2t is not the definite reason for the sudden increase in fuel efficiency.
hmmmmmmm.
So... if you guys are serious about it,
wanna tear apart engine/carb, we need to decide how long it has ran with the 2T additive before taking apart. How long for the 2T gunk/carbon deposits to build up?
1 month? 3 months? 6 months? 1 year? 2 years? 5 years?
or
5,000km? 10,000km? 20,000km? 50,000km? 100,000km?
To be fair, we also need 'before' and 'after' pictures... which means we need to take the engine apart first before starting the experiment, then run with fuel + 2T additive, then take it apart again. Not once only. Because nobody can say for sure whether the engine is already gunked up before starting the test.
And then what type of 2T?
Mixture need to be fixed. Ratio?
There are many other variables that needs to be controlled in order to make this an objective test.
Just a little input...:)
After thinking about it... checking the spark plug will be the cheapest (even free) option... Apart from the Fuel line, Carb, intake valve, combustion chamber, exhaust valve, finally exhaust... the plug happens to be where the 2T is burnt. Any incomplete burning of fuel/2T/Impurities will all show on the plug tip. just take it out and check...
Edited by Limsteel
91-92: 84 Yam LC125
Research 101, if I may, I wish to highlight some important factor for evaluation.
The primary hypotheses is: adding 2T increases fuel efficiency.
1) Evaluation FC for 30 days Before "2T-treatment" and After treatment. (Pre-Post treatment test).
2) The "tester/rider" must evaluate if the output (e.g. torque, top-speed) had any deviation from the norms.
3) Temperate reading from a gauge to detect accurate change in engine temp.
4) Tester should also account for the environmental condition during 1) pumping of petrol 2) usage of vehicle
-as different climatic condition affect molecular behavior- data should be logged and collated.
5) Tester should take note of riding style (rpm of gear change) to avoid contributing human error in the finding.
6) This research should not last more than 3 months as other wears on the vehicle may influence the finding.
Other experts in this field can help to chip in.... e.g. vehicle make, model, year, 92/95/V-power, tyre pressure etc.
Best Regard
try it once :o
to all those who want to test the hypothesis..
understanding DOE...should be done..
other non orhodox testing will results in more controversies than answers...
Den is it ok to add abit of 2T inside the fuel tank for 2 stroker?
Not premix
To ride on the road, You need skills,Stamina, or even luck.
But to be a good rider, you have to change with your environment,and adjust yourself to its rhythm.
Cultivate the confidence to face the different situations. Don't let yourself to be subdued by the environment :thumb:
Design of Experiment in this scenario? Don't think anyone has the dedicated resources to conduct conclusively.
Gonna need identical engines running identical loads over extended periods. And even then, won't be representative.
Save the engineering specifics for elsewhere. If suggesting that FOR the hypothesis requires specific scientific results, then it must apply to the reverse. If one wants to disprove the hypothesis, then better have a paper to back it up and not he-say she-say evidence.
It's all purely anecdotal here. Take everything with an open view and do NOT put down others' views unless you can conclusively prove it.
One method which might be easily doable is to obtain a boroscope(fibre optic scope, like those you see in spy movies), stick it into the intake tracts to view deposit build up or lack of around intake valve/seat/seal. Likewise, can view via sparkplug hole, combustion chamber. Less invasive than tearing apart engine to see.
SBT #1149 Price List
Not premix
if u alr hv ur 2T pump working, plus u add more 2T to ur petrol directly, ur 2T mixture will be too much la.. scared ltr will foul ur spark plug
Depends ah, your 2T pump doesn't mix that high a ratio, besides, put a lil bit won't hurt. Its like a play safe thing if you're riding high rev and long distance.
yeah...doe a piece of sh it as some says....
good luck to the testing.....any way..doe is doe..
if you dont understand what i say....then go to school again.
latest update,
2t infused petrol = 39.61 km/l. earlier range was 36.17km/l and 41.87km/l
no 2t = 34.45km/l
with 2t, higher fuel efficiency.
latest update,
no 2t = 34.45km/l
Awesome right. with my steed 400 im getting about 30kpl consistently
guys anyway to take a peek at the plugs?
Honda Shadow ACE 400 1997
V-strom 1k
Dr 200
remove the spark plug and just look at the colour of the tip?
Actually is take a look at the white ceramic part just after the tip. The inside portion of course.
My bike stock was running lean. cannot go above 95. 40km/L
After tunning abit more to the rich side (extra by 1/4 turn) 32KM/L but can reach 110km/h.
I think most pf us are curious, with ur increase in fc efficiency. Does ur engine runs lean or suffer plug fouling.
Do post a pic if possible. Guess that will satisfied most of our curiousity
I feel, those who are interested in the experiments. Can do 2 things.
Plug check. Think this is standard. This will tell if bike is running lean or if the plugs foul.
Or can invest in a colortune.
Yes will update during my next servicing.
Can fell my bike running slightly lean now but thats before the 2t addition as well.
Like some say, DOE is important when doing precise study.
Ok, so in that case, for those who want to say that 2T harms engine, have to do DOE also to show that it is damaging to the engine. How about that? If cannot, then, go back to school to study.
As mentioned, here ppl are talking about anecdotal experiences. If particular parties feel that this is not precise, then perhaps they should relook their assertions that 2T in fuel is BAD for the engine. Any DOE or papers published on that? If not, how can you be SURE.
Saying again and again, here is to share their experiences. If you do not have something constructive, e.g. negative or positive Personal experience, then do not go traipsing around putting down other ppl. If don't know what I am saying, go back to school to study.
maybe he should go back to school of morals, never seen some one here so rude and childish. Anyway kudos to the TS who shared this going try it after I keep a thread record of my fuel usage for 1 month then I try 2t oil if i got the guts
colortune would be cool. but then again, got distributor here?
i also realised recently, after i lean the mixture abit, my bike cannot go above 100km/h.
i remember the 1st time i put in 2t, the bike was able to hit 130km/h! and it wasn't even reving extremely hard. i might just rich back the mixture again to see if there is better response.
